Re: Question For Gene Bender
Posted by El Toro on January 30, 2006 at 18:23:16 from (205.188.116.133):
In Reply to: Question For Gene Bender posted by Red Dave on January 30, 2006 at 17:00:11:
I used dish detergent on the seal and on the lip of the sleeve. Make sure the recessed area for the sleeve in the block is clean. I didn't use anything but the headgasket when installing the head. No leaks either. Make sure the area in the block where these seals are installed is clean
of all dirt or rust. Very important. Hal
PS: I covered the seals with water after installing the sleeves and let it sit all night
to check for leaks.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
