Farmall Tractors Discussion Board |
Re: H Plugs! Hot or Cold?
Posted by Phil Auten on January 06, 2000 at 19:09:05 from (206.175.72.226):
In Reply to: H Plugs! Hot or Cold? posted by john on January 06, 2000 at 15:49:09:
John, I'll try to explain this. A "cold" plug is slightly recessed into the threaded portion of the plug so it runs "cold" compared to a plug with a "hot" heat range which has a longer insulator and center electrode to extend it out into the combustion chamber. This causes the heat generated by the burning fuel to have to travel further through the center insulator before it reaches the head where it is carried away to the radiator by the coolant. The "hot" plugs ignite the fuel/air mixture more easily than the "cold" plugs. The difference in length between the center electrode of the coldest plug and the hottest plug for the same application is usually less than 1/4". There may be 4 heat ranges within that 1/4". In cars, one that gets all it's driving done on freeways might use a "cold" plug as it will usually be operating at optimum temperature. The same car, if driven mainly for short trips at low speeds might use a "hot" plug to make better use of it's ability to ignite the fuel mix that a "cold" plug might not be able to fully ignite, thus improving performance. Does this help any? The other thing that is often done is to substitute a "hotter" plug where the "normal" plug keeps getting fouled due to incomplete combustion forming those sooty carbon deposits. I've seen plugs foul in just a couple of minutes in this situation. Replacing Champion D-15 plugs with D-17's or D-21's can solve this problem. However, care must be taken to watch for signs of detonation caused by the spark plug's tip becoming too hot and firing the mixture too soon. This can lead to burned valves or pistons, which is NOT desirable! So there are many considerations to choosing the correct spark plug for your particular need. Phil
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
