Re: F-12 motor
Posted by Mike Androvich on January 31, 2006 at 15:07:44 from (69.171.91.21):
In Reply to: F-12 motor posted by farmallboy on January 31, 2006 at 14:03:34:
No. An F-12 engine has wet sleeves, and they are available at a number of places, most notably Weber's Tractor Parts, or Rice Equipment to name a couple. As far as a complete rebuild set, I doubt if you are going to find a complete set. You will have to find what you need from several sources.
