Re: Valve grinding
Posted by Larry Condon on February 01, 2006 at 05:47:00 from (206.10.12.159):
In Reply to: Re: Valve grinding posted by Kelly C on January 31, 2006 at 21:34:55:
If the valve needs grinding, will the valve seat also need grinding? Possible the valve guide need replacement? And if the valve stem is worn the whole valve need to be replaced. I'm interested in how this project comes out for you.
Larry
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
