Re: m carb adjustment
Posted by old on February 01, 2006 at 17:09:50 from (207.69.137.21):
In Reply to: m carb adjustment posted by bm3501466 on February 01, 2006 at 16:58:33:
I'd leave the idle screw alone as long as it idles well. The load is the one you need to adjust. turn it out a little at a time till you find the sweet spot.
