Re: another C question
Posted by Hugh MacKay on February 01, 2006 at 17:49:21 from (209.226.106.14):
In Reply to: Re: another C question posted by Andrew Z on February 01, 2006 at 17:35:30:
Andrew: Ahha, that explains it. My thoughts were to not use the cover from IH, but rather shape a section of 1" plate size of that cover, drill the 4 - 1/2" holes, then drill a 1.5" hole for the shaft to protrude into. Make a second 1/2" plate same shape and just the 4 matching 1/2" holes. This 1/2" plate will cover the 1.5" hole. Then weld the two plates together. Then weld tabs centered for hitching top link. This makes a real neat job, or at least the ones I've seen did.
