Re: removal of W6 clutch and tranny
Posted by Haas on February 01, 2006 at 18:24:52 from (12.65.42.58):
In Reply to: removal of W6 clutch and tranny posted by mwilke on February 01, 2006 at 12:06:16:
The clutch release shaft is the cross shaft that operates the clutch release fork when you push in the clutch. To take it out, you must remove the bolts that clamp the clutch release fork to the cross shaft. Two heavy washers between the clamp key the clutch relase fork to the cross shaft. Once that stuff is loose, and the clutch pedal rod is off (unless I forgot something) the cross shaft will just slide out and the clutch release fork will then also come out. Once you have that follow the directions Chadd gave you to release the pressure on the clutch disk and you should be able to pull and tilt the main drive shaft (the one with the splines that goes into the clutch) enough to pull it out. That is after you have taken the main drive coupling to the transmission out.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
