Re: 1066 - Tractor Vet
Posted by the tractor vet on February 01, 2006 at 18:47:44 from (4.124.88.67):
In Reply to: Re: 1066 - Tractor Vet posted by Michael Sheik on February 01, 2006 at 18:18:07:
I do not use Hy Tran for a lube on assambly i use white grease outboard motor grease or engine assambly lube OR go ahead and laugh K Y Jelly Venner slider.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
