Re: O/T Chevy intake leak !!!!
Posted by lee on February 02, 2006 at 16:57:46 from (12.6.155.115):
In Reply to: Re: O/T Chevy intake leak !!!! posted by Janicholson on February 02, 2006 at 14:00:30:
I would second the notion that possibly the fit-up is to blame although sealing a manifold can be tricky business even with good fit-up. Lots of guys use the RTV across the valley rails. If you are using cork I would not use RTV but probably a hi-tack type adhesive cement and only very thin coat and only after checking to be sure the amount of squeeze (gap) is correct, too much/too little can be problematic. If using neoprene or silicone molded rail gaskets I'd put those in dry and pristine clean no oil, no hi-tack or sillycone. But your problem is really with the two manifold gaskets as that's where the water passage is so you need a good set of gaskets and I would hi-tack spray adhesive those a very thin coat allowed to nearly dry before very careful and precise placement on the heads and if there are any bolts running straight in i'd use long bolts with heads cut off or pins to guide the manifold straight down into place. Then you got to torque it slow and careful and bring it down int final position. manifolds can be a PITA. I've done my share. Worst I ever did was a Ford V6 3.0 I think took 3 tries to get her done then wrecked it two months later so don't know if strike 3 held or not. My problem was corks squezing out.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
