Re: M not running right
Posted by Wayne Swenson on February 02, 2006 at 17:42:03 from (66.191.70.114):
In Reply to: M not running right posted by bm3501466 on February 02, 2006 at 16:13:18:
#1. Loosen the 2 screws that are holding the governor tube & gently tap it so it "centers" itself then tighten the screws. Remove the top cover on the governor (has the pipe going to the top of the engine) and check governor to carburetor synchronization. With the throttle wide open, the clevis pin should just slip into the governor connecting rod that is in the tube. Adjust the clevis height if needed & lock the nut. You will need small fingers & a right angle needle nose pliers to make the job easier. #2. With the engine warm & running at wide open throttle (WOT), turn high speed mixture screw in until the engine begins to starve for fuel. Then turn the screw out until the engine begins to blubber. Now find the "sweet spot" in between the two settings. If you are working the engine (plowing, etc.), then the high speed screw needs to be turned out 1 turn or more beyond the "sweet spot" to be sure the engine isn"t starving for fuel and can develop its rated power. The same procedure can be followed for idle mixture with the addition of the ldle stop screw to set the low speed RPM. On the "M" carb, the idle mixture screw is an air adjusting screw so turning in will richen the mixture and out will lean the mixture. Aren"t carbs fun!!
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
