1066 - Tractor Vet - FINALLY
Posted by Michael Sheik on February 02, 2006 at 19:00:49 from (64.250.199.238):
As I write this it is 9:00 PM here. I finally got the leak fixed and what I did was exactly what I posted this morning. A minor but large detail on assembly done incorrectly sure can screw things up! You learn by your mistakes. That is how I learnt most that I know. At least the other side will be easier if that one starts leaking.
I also noted that the shaft at base of two point arms has stopped leaking. Maybe it just needed a little running time and oil on it to swell orings.
Feeling good right now and going to try it out some more Saturday.
See ya tomorrow - Bed time!!!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
