Re: SC wide front bushings
Posted by chadd on February 03, 2006 at 05:10:39 from (155.92.169.92):
In Reply to: SC wide front bushings posted by leon on February 03, 2006 at 04:16:29:
I would try the IH dealer first. If it is like with our W6, they won't carry them anymore. What our dealer did is they went through a bin of leftover bushings, and came up with a split bushing that was close. We had the outside turned on a lathe by a machine shop to make it fit. The bushing is steel backed with a bronze inner surface.
