Re: MD MISS
Posted by Haas on February 03, 2006 at 07:03:46 from (12.65.67.202):
In Reply to: MD MISS posted by Mixman on February 02, 2006 at 19:13:13:
If you have good compression through the spark plug, that would seem to indicate that there is a problem with the "third" valve which is the decompression valve. You can pull the valve cover and check to see if it is stuck, or not set properly so that it is not closed when in diesel. If stuck, you can probably free it up with some penetrant and working the valve. If not, looks like you will have to pull the head to fix it.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
