Re: Carp - antifreeze in oil showed up again
Posted by Janicholson on February 03, 2006 at 15:45:16 from (66.173.50.90):
In Reply to: Re: Carp - antifreeze in oil showed up again posted by El Toro on February 03, 2006 at 14:27:40:
Water put into a radiator from the tap, or rainbarrel will have trapped gasses in it. I would be sure it is combustion gasses before tearing out hair. A HC meter on a emissions tester will show what it is made of (your noes is also pretty good)
If it stops after two or three start and warmup cycles it is not broken. A cooling system pressure check at about 6 PSI max, left on for 20 hours will also blow coolant the otherway through a bad gasket/crack. Good luck.
JimN
