Re: 656 Hydraulic Problem continued
Posted by IH GARY on February 03, 2006 at 18:53:10 from (66.226.101.101):
In Reply to: 656 Hydraulic Problem continued posted by Don, Ohio on February 02, 2006 at 20:15:01:
The reason the flywheel bolts had sealer on them is the hole in the crankshaft go clear through into the crankcase.Need some type of sealer or lock-tite on the bolts. The clutch shaft will move freely but there is a coupler on the end that goes into the sun gear on the TA. Suggest don"t pull on the shaft. Coupler might be loose on the clutch shaft. If it falls of you will have to take the top cover on the TA housing off to put the coupler back on
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
