Re: 560 questions
Posted by ejr-IA. on February 03, 2006 at 19:39:21 from (4.228.51.78):
In Reply to: 560 questions posted by Mcred on February 03, 2006 at 14:30:16:
According to the parts book I have their the same.You said clutch don't know about the flywheel.I have put two 301 engines off of combines into tractors a diesel into a 560 and a gas into a 460 you will have to find some tractor engine parts to make it work.Post again if you have ?
