Re: H Carburetor stumped on adjustment after rebui
Posted by CNKS on February 05, 2006 at 11:06:28 from (204.249.178.138):
In Reply to: Re: H Carburetor stumped on adjustment after rebui posted by CNKS on February 05, 2006 at 10:58:15:
Sorry, misread your 1st sentence where you said you used carb cleaner -- I would soak it again. You can tell whether most of the passages are clean by seeing if you get air out somewhere when blowing it out. I would go easy with the manual cleaning. The problem with the lack of response to the main adjustment is a common one. A new needle and seat should take care of it, provided the passage is clean, IF you can get the old seat out.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
