Re: d436 temp sending unit
Posted by IaGary on February 05, 2006 at 20:20:47 from (216.51.139.212):
In Reply to: d436 temp sending unit posted by D Sellers on February 05, 2006 at 17:04:48:
DSellers those wire connections like to corrode on the sending unit so try cleaning the connections to see if that will fix it. I've had to do it several times.
