Re: M starts fine then dies. HELP!
Posted by old on February 05, 2006 at 21:16:19 from (4.244.186.243):
In Reply to: Re: M starts fine then dies. HELP! posted by Granger on February 05, 2006 at 21:13:31:
Yes a carb kit would probably fix the problem. Instructios are in the kit if its a good one. You should also soak it in carb cleaner and then blow it out with air and also use spray carb cleaner in it to make sure all passages are open.
