Re: M starts fine then dies. HELP!
Posted by Brownie 45 on February 06, 2006 at 01:58:44 from (207.177.82.194):
In Reply to: M starts fine then dies. HELP! posted by Granger on February 05, 2006 at 20:18:26:
If you have adequate fuel flow, Suspect the condenser[or points]. We have been having lots of trouble with condensers causing troubles such as you describe. Intermittent & mysterious stalling, backfiring, anything you can imagine. I believe that the condensers we are getting now are all imports. If only Filko ignition parts were available again.
