Re: !aGary-1066 Aux. Control valve
Posted by IaGary on February 06, 2006 at 05:56:06 from (216.51.139.212):
In Reply to: Re: !aGary-1066 Aux. Control valve posted by IaGary on February 06, 2006 at 05:45:35:
I talked to mechanic and he said kit ti rebuild is around $7 at IH. You have to replace the whole shaft with the little o-ring because you will damage it to replace it. And replace the other orings and that was it. There are 2 styles of shafts and they both work in the same valve.
Good Luck.
