The good zero turns will run you about 9 to 10k or more at 52"+. They are necessary if there is a lot of stuff in the way, that is trees and landscaped areas. At equal width, the zero turns will not work any faster than the SA in open space except that the zero turn does not waste as much time at ends. For wide open space the SA will do just fine. If you let the grass get deep, do not expect to get far above first gear, second at the most and you may have to double back over. If the blades get dull, it will not cut well. I use a 6-foot finishing mower behind a Ferguson 50 with a Perkins diesel to cut about 5 acres with trees and steep ditch bank but no major landscaping. It takes me about 4 to 5 hours but there is a lot of weed eater work and I only get there about every 3-weeks. Also remember that the PTO on the SA is not live. You will not be able to ease up to tight places or change direction without comming to a complete stop.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
