1066 Third time the charm?
Posted by Michael Sheik on February 07, 2006 at 04:40:47 from (199.153.205.246):
Well, had the IH mechanic tear apart the auxiliary control valve yesterday evening. When he did we found that the oring on the actuator tube(on threaded end) had a small piece cut out of it(not completely broke). He checked to make sure the plug, oring and backup washer were seated good in the actuator and they were. Nothing else was found to be wrong except that one oring. I put back on tractor and ran for 10 minutes with no leak noticed. That happened last time too and lasted for 3 hr field work. All I have left is 3 or 4 hours field work so at least maybe I can get through that. A little something he told me that you all might want to know is that when you are unscrewing the actuator out of the spool, utilize screwdriver slot to remove actuator and sleeve holding detent balls as a unit and when you go back do reverse and do not overtighten (that is probably what I did). He did not remove the sleeve from actuator nor did he unscrew the adjusting plug from inside of actuator. He also only hand tightened the hex head cap and told me to only hand tighten sleeve into valve body.
Home
| Forums
Today's Featured Article -
Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
