Re: Round up ready spray pump
Posted by Hugh MacKay on February 07, 2006 at 04:49:31 from (209.226.247.120):
In Reply to: Round up ready spray pump posted by Avery on February 07, 2006 at 04:14:37:
Avery: I have to agree with Nat, a pump is apump is a pump, don't think it will matter what the chemical is.
Only experience I've ever encountered with spray pumps is some of the wetable powders were very hard on roller pumps. Piston, diaphram or centrifical pumps stood up to those much better, enough so, they were more economical. Then when it came to insecticides requiring higher presures, piston or diaphram were the only way to go. Roundup is so far from any of that criteria, I can't see it needing any special pump. Roundup is the same chemical regardless of whether you spraying it on a roundup ready crop or any other application.
If you are using hydraulic agitation then a high volume pump like centrifical does have some bnefit, but that would be the same with any chemical.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
