Re: Noisy A
Posted by Janicholson on February 07, 2006 at 05:56:38 from (199.17.6.175):
In Reply to: Noisy A posted by Iowaboy on February 07, 2006 at 05:49:41:
More info is needed.
We get the sound, but is it under load, all the time it is in motion, when slowing?
Is it from the front, middle, rear?
is it changing from gear to gear?
does the frequency of each rear change depending only on engine speed?
Help us help you.
JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
