Re: Noisy A
Posted by gene bender on February 07, 2006 at 11:52:50 from (66.43.221.211):
In Reply to: Noisy A posted by Iowaboy on February 07, 2006 at 05:49:41:
Those werent the quietest tractors because of the straight cut gears. Try 140wt in the trans and also the final drive this helps some. If the input bearing is bad in the tranny that can also make noise. I would drain both pans on the final and go to the 140 then drain the tranny and put it in there also. Both that i use on the WMT tractor ride have been changed to 140.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
