Re: 5288 spindle
Posted by chadd on February 07, 2006 at 11:59:46 from (155.92.31.116):
In Reply to: 5288 spindle posted by ross s on February 07, 2006 at 10:27:55:
Wow!!! How in the world could that many spindles break one after the other? Definitely doesn't sound like a coincidence. Those front ends were designed to be able to handle those big huge tractor mounted chemical tanks. I would think that if they were built strong enough to do that, bouncing through a field would still not tax any front end part beyond its limits. Either you are getting defective spindles, someone is driving WAY too fast through plowed or rutted fields, or something is damaged or bent in the front end and is causing excess stress on that spindle.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
