Re: Battery box or tray? 1940 H. My FIRST Red Trac
Posted by farmallhal on February 07, 2006 at 16:01:56 from (64.24.35.17):
In Reply to: Battery box or tray? 1940 H. My FIRST Red Tractor! posted by Randy G. on February 07, 2006 at 10:49:05:
Randy, I went and measured my H's battery box so you would know the size you are dealing with. The box is 7" wide, 9" long and 8.5" high. I think you will find several 12 volt batteries will fit in those deminensions. You don't need a high capacity CCA rating as the starter will turn over like it never has before. With some luck your existing battery might fit within the above deminensions. Good luck, Hal
