Re: Farming with old iron..... value of 966
Posted by Sloroll on February 08, 2006 at 04:41:36 from (69.66.221.164):
In Reply to: Farming with old iron..... value of 966 posted by farmallwayne on February 08, 2006 at 04:27:42:
Have you priced the new 100hp tractors?
I grew up on a 966 and they are a great machine. I am sure there will be someone to argue that point as there always is. They are built to grunt though. Every once in awhile you'll want to take it out and pull it near it's limit just to keep it's knees streched. Ours was owned for 30 years with no maintanence issues other than oil and filter changes. We pulled 5 bottoms and an offset disk with it in the spring and pulled the sunshine spreader with it all summer, fall and winter.
