Re: Farming with old iron..... value of 966
Posted by captaink on February 08, 2006 at 07:02:16 from (66.115.214.56):
In Reply to: Farming with old iron..... value of 966 posted by farmallwayne on February 08, 2006 at 04:27:42:
I was reading the reply from Baelee05 and it jogged a few thoughts. I put a loader on a 966 and I have to agree that the shifting can get to be a touch aggravating however, if you get into the habit of getting into neutral JUST before you stop moving it helps. Keep the transmission brake set up and it will go into gear fairly easy. Make sure that it has a water filter on it and if possible find out if it has been changed and how often or if radiator treatment has been used in the anti-freeze. Cavitation of the sleeves and or block is a common issue in the early X66 series. Once I put the loader on my 966 I started having problems with clutches. The damper springs in the clutch would break and start to fall out and jam things up. I finally put a flywheel and clutch in from a 1466 (get the hydraulic assisted one if you can) and had a custom made clutch that had fiber pads instead of the ceramic ones. This made it shift a LOT easier AND ended my clutch issues. I’m not sure if the bigger clutch or the fiber pads did the trick since I did both at the same time. I don’t mean to scare you away, just want to let you know my experience. I like the loader on the 966, it’s not terribly awkward, and with a bale fork on the back it will handle 2 big round bales just fine.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
