Re: 1941 MODEL A POPPING THROUGH EXHAUST . HE
Posted by Janicholson on February 08, 2006 at 11:53:39 from (199.17.6.175):
In Reply to: 1941 MODEL A POPPING THROUGH EXHAUST . HELP! posted by Kevin Billups on February 08, 2006 at 11:39:34:
Do a compression check on #1 (if no gauge, hand crank in neutral with ign off with thumb over plug hole). if no compression, pull valve cover and check for a stuck valve. If all are moving, adjust them. There could be a chunk of crud under the exhaust valve, if so the exhaust valve on #1 will be loose when adjusted, instead of ~.020 it will be more like .050 or more. If it is, just running it for a few minutes might clear it. Or tapping on the stem of the valve (downward with the rockers removed) may also break crud off of the face/seat.
If problem remains, do a leakdown check to see where the air is going.
Good luck
JimN
