Re: 1941 MODEL A POPPING THROUGH EXHAUST . HE
Posted by captaink on February 08, 2006 at 11:56:50 from (66.115.214.56):
In Reply to: 1941 MODEL A POPPING THROUGH EXHAUST . HELP! posted by Kevin Billups on February 08, 2006 at 11:39:34:
Check the firing order (1-3-4-2) to make sure the spark plug wires are on correct. Make sure that the magneto timing is correct.
If that checks out, take out the number one spark plug and put your finger over the spark plug hole. Turn the engine over by hand until you feel pressure coming out of the spark plug. If don't feel pressure, you probably have a stuck exhaust valve on that cylinder.
If you have pressure and the spark plug wires are right then check the valve clearance to make sure it is correct.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
