Re: skipping Farmall A
Posted by old on February 08, 2006 at 12:22:23 from (207.69.139.147):
In Reply to: Re: skipping Farmall A posted by Russell S. on February 08, 2006 at 11:13:25:
Well since its a mag then you can still replace the point and condenser, which may help. If you have black smoke that means its running a little rich. If it has a main jet adjustment you might turn it in a little. If it doesn't then you may still have a porblem in the carb, ya I know you siad you rebuilt it but some times they can be a bear to get just right
