Re: Alcohol in gas
Posted by Janicholson on February 08, 2006 at 14:35:58 from (199.17.6.175):
In Reply to: Alcohol in gas posted by Erik in WI on February 08, 2006 at 13:36:57:
Ehhanol is fine and will clean crud (though temporarily bothersome not an issue. High speed and Idle may need 1/2 turn richer or so.
Methanol is the bad very bad type of alcohol.
JimN
