Re: Took longer to do than to read about - really
Posted by KEB on February 08, 2006 at 19:14:11 from (209.108.192.162):
In Reply to: Took longer to do than to read about - really posted by williamf on February 08, 2006 at 18:45:33:
Try drilling it out with a left hand bit. I've had several broken bolts decide to back out from having a left hand drill bit run down the center. Realize you'll have to either go to town to get one, or order one from somewhere, but still a lot less trouble than dropping the oil pan.
You might also try a little heat from a propane torch. Make sure the area you're heating is well cleaned off first so you don't set the grease or oil on fire, & be careful not to get it too hot. Try to heat the pan around the plug more than the plug itself. Sometimes a little heat will soften whatever crud is stuck in the threads.
Good luck,
Keith
