Re: 12 volt conversion diagram
Posted by John T on February 09, 2006 at 12:50:17 from (66.244.90.98):
In Reply to: 12 volt conversion diagram posted by RBoy on February 09, 2006 at 12:25:10:
R Boy, for sure the good Bob M has great wiring diagrams and he can help you, no use in re inventing the wheel again huh. It sounds like youre already there, however, if you already have a ballast resistor and the 12 volt genny and 12 volt VR and a new battery I assume. You said VR, so I assume its a VR and not a cutout relay?? Regardless, its BAT terminal still wires to the ammeter (load side) and its other terminal to the gennys Arm post and it has to be to match your ground. Simply hook the genny and VR up and polarize the genny (I assume youre still at positive ground, if you changed grounds, the ammeter leads need reversed and the coil needs to be wired to match the polarity youre at). The wire that used to go the the BAT terminal on the old VR still wires to the BAT terminal on the new VR, and the VR's Fld terminal wires to the gennys Field post, and the VR's ARM (GEN) wires to the gennys Arm post. Simply wire the ceramic ballast resistor in the ignition circuit ahead of the coil so its between the switches output and the coils input (NOT to distributor) terminal. You could simply use the wire to the coils input now but remove it from the coil and wire it to the ballast instead, and then run a new wire from the other side of the ballast to the coil. The ammeter and starter will be okay and so will the points and condensor, but the lights need changed to 12 volts. Good luck, John T
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
