Re: farmall 706 quits running
Posted by old on February 09, 2006 at 20:24:28 from (207.69.137.206):
In Reply to: Re: farmall 706 quits running posted by Troy Schwartz on February 09, 2006 at 20:03:23:
I would start with the cheap easy fix and go from there. I would first check that you have good gas flow to the carb when it does that, pull the drain plug from the bottom of the carb and make sure you have a good steady flow of gas. Also when it shuts down check to make sure you have a good blue spark. If the spark is weak try a hot wire from the battery to the coil to make sure is not a switch or wiring problem. If it runs good with the hot wire then the problem is from the coil back. If the hot wire doesn't help then I would do the good old points, condenser, plugs, cap and rotor. Then if it still dies I would try the coil. Doing it that way you go from cheap to higher priced stuff
