560 with a 806 head help!!!!!!!
Posted by VOLfarmall on February 10, 2006 at 06:35:58 from (66.19.136.70):
I have a 560 gas that I use for a pulling tractor. Also Ihave a 706 gas that runs real good both have the 263 engine I was going to switch the heads because the 706 has a higher compression ratio ,when I got the heads off I checked the numbers and the head from the 706 came off of a 806. the 560 has the step head pistons in it and the 706 has a different piston it looks like barn roof right in the middle but it is not as high as the 560's. the problem is when I put the 706 head on the 560 the pistons hit the head. What kind of pistons do I need in the 560 to make this work.
