Re: C135 engine in Farmall A
Posted by Bill46 on February 10, 2006 at 10:18:41 from (63.65.68.28):
In Reply to: C135 engine in Farmall A posted by Charles Barger on February 10, 2006 at 07:39:21:
I have one I did Charles...it's a 153 off a combine. I am sure a 135 would be easier. My biggest problem was getting a pilot bearing and throw-out bearing to work. I finally took an old shaft from a super C and cut it down. The 153 has no hole in the crank for a pilot bearing.
A 135 may drop right in...but watch that crankshaft. It may or may not work.
