Re: 656 Ring gear and starter
Posted by Janicholson on February 10, 2006 at 12:55:31 from (199.17.6.175):
In Reply to: Re: 656 Ring gear and starter posted by Yellott Canby on February 10, 2006 at 12:11:56:
Put a smaller bolt in the starter than original, or grind one side of the same size bolt and install it so that the starter can be "adjusted" just a bit upward. That should eliminate the bind!
Did you try the idea of removing all wires but the fat one?
JimN
