Re: Fairway 12 McCormick Deering.
Posted by El Toro on February 10, 2006 at 14:45:30 from (152.163.100.65):
In Reply to: Re: Fairway 12 McCormick Deering. posted by El Toro on February 10, 2006 at 05:08:21:
I was told they used Hercules in these tractors.
Here are the model numbers used and the F12 Farmall used the Waukesha engine without overhead valves. Pre1928 used mod YXA, 1928-32 Y-X-B, 1929-40 OOC and then model IXK. Hal
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
