Re: 656 Ring gear and starter
Posted by Yellott Canby on February 10, 2006 at 18:36:03 from (4.131.39.79):
In Reply to: Re: 656 Ring gear and starter posted by Old Dutch on February 10, 2006 at 13:34:46:
Hello, Thanks for the idea of the washers. I tried shiming it out with two washers at each of the 3 bolt holes. Still did the same thing. Would you try to angle the starter slightly by shiming the furthest hole with two washers while shiming the closer two hole with one washer each?
That would angle the starter slightly away from the ring gear. Do you think it would tear anything up?
Thanks YC
