Re: skipping Farmall A
Posted by Brownie 45 on February 10, 2006 at 18:59:26 from (207.177.82.239):
In Reply to: skipping Farmall A posted by Russell S. on February 08, 2006 at 08:54:17:
Was the engine running well during warm weather? If it is running rich after cold [below freezing] weather, check for ice build-up in the oil bath air cleaner cup, which is maybe restricting air flow. We used to operate our A alot in snowy conditions. Oilbath air cleaners see snow as solid material[dirt] which it rightly deposits in the cup. Along comes a warm day, & the snow melts leaving water in the bottom of the cup. After enough freeze/ melt cycles, air flow down the air intake pipe is restricted/ blocked & you get black smoke/no running. Ours was totally blocked once, but warming the cup & getting the ice out restored proper operation. Worth a look.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
