Re: 400 pto band question again.
Posted by Janicholson on February 11, 2006 at 08:26:09 from (66.173.50.183):
In Reply to: Re: 400 pto band question again. posted by Kelly C on February 11, 2006 at 08:17:47:
Shimming the end of the band might get it to work temporarily. Be sure there is no metal band component threatening the drum. Letting the implement slow down on its own by not clipping the control lever forward will be kind to the bands (but not slow the machine as rapidly as the brake band will. I never latch it in brake mode with a high inertia bush hog or bailrer with massive fly wheel, unless it is necessary for safety.
JimN
