Re: sassy 706
Posted by El Toro on February 11, 2006 at 16:40:32 from (152.163.100.65):
In Reply to: sassy 706 posted by Troy Schwartz on February 10, 2006 at 20:12:21:
You can jumper around a ballast resistor with another wire feeding voltage directly to your coil. Then if the tractor stays running you've found the problem. I would then get a new resistor before using the tractor. Hal
