CUB IH CARBURETOR
Posted by FLOPGUNS on February 11, 2006 at 18:49:39 from (207.144.147.88):
HELLO I GOT TWO IH CARBS THAT THE IDEL TUBE IS BROKE OF IN THROTTLE BODY ASSEMBLY. I THINK THAT THEY ARE TREADED ON THE END THAT GOES IN THE THROTTLE ASSEMBLY. HAS ANY ONE OUT THERE HAD ANY LUCK GETING IT OUT AND WHERE COULD YOU GET A NEW IDLE TUBE THANKS FLOPGUNS
