Re: Ring Gear Problem
Posted by Les Ball on February 11, 2006 at 19:56:53 from (12.210.189.103):
In Reply to: Re: Ring Gear Problem posted by CNKS on February 11, 2006 at 19:28:01:
loose meaning, when I turn the starter over, it spins the ring gear, but not the flywheel. Thanks for your input. I do know the Super A was locked up when I had it, so perhaps someone had tried to force it to turn over and severed the ring and the fly ? - les
