Re: 584 Grill
Posted by DADDY E on February 11, 2006 at 20:40:37 from (69.158.39.108):
In Reply to: 584 Grill posted by Stubober on February 11, 2006 at 15:12:25:
I HAVE A 574 (ITHINK THE GRILLS ARE THE SAME). MY
GRILL WAS BROKEN BUT I HAD ALL THE PIECES.
I REMOVED THE GRILL FROM TRACTOR TURNED IT OVER AND USING METAL STRIPS (I USED AN OLD HALF INCH BAND SAW BLADE).
STAND THE METAL STRIPS ON THEIR EDGE AND USING A HOT HELT GLUE GUN,LAY A LAYER OF HOT MELT THE LENGTH OF THE CAVITY IN BACK OF GRILL AND INSERT THE METAL STRIP AND LET IT COOL. DO THE SAME FOR ALL AREAS NEEDING REPAIRED. THEN REPEAT THE GLUE LAYERS LETTING IT COOL BETWEEN PASSES UNTIL THE CAVITY IS FULL AND THE METAL STRIP IS ENCASED IN THE HOT MELT. MAKES IT VERY STRONG. I DID MINE 15 YEARS AGO AND IT"S STILL A-1, AND NO THE HOT MELT WON"T MELT ON A HOT DAY..........ELDON FROM ONT.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
