Re: Ring Gear Problem
Posted by Fierce Sparrow on February 12, 2006 at 09:32:39 from (206.40.122.34):
In Reply to: Ring Gear Problem posted by Les Ball on February 11, 2006 at 18:04:19:
I have pulled apart many tractors in my lifetime and have seen quite a few with the ring gear welded to the flywheel. The best is to use stainless steel welding rod because of its high tensile strength and superior bonding qualities with dissimilar metals. Best is to weld on the opposite side of starter engagement so as not to cause interference with starter function. If not possible, make sure ring gear teeth are not damaged. Also, seeing as a four cylinder always stops in one of two places, make sure you don"t have the two primary engagement spots on the ring gear where they have been if they"re worn. Easy way to check is to start the tractor, and then shut it off. It will stop in one of the two places it always does, and you can peer into the starter hole and see if the teeth are worn. If so, give the ring gear a quarter turn.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
