Re: NO SPARK
Posted by El Toro on February 12, 2006 at 17:13:35 from (205.188.116.133):
In Reply to: NO SPARK posted by Glenn (OH) on February 12, 2006 at 16:42:38:
Do you have voltage at the coil while cranking the engine? If your're using a negative ground on your battery, the wire from the - negative terminal on your coil should go to the distributor. Pull the coil wire from the distr. cap and hold within 1/4" of a good ground on the tractor frame. Have someone attempt an engine start. Should have a hot blue spark. No spark, check for voltage at the coil when trying to start with the ignition switch in the on position. Make sure your wire connections on the points aren't touching a ground in the distr. Are you using a ballast resistor? Hal PS: You can run a wire from your battery directly to the coil. This would bypass your ignition switch.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
